Warning reported from application Results - Patran
When I read the results of the analysis with Patran, into the bottom bar comes out the following message:
$# Warning reported from application Results
$# The specified results refer to a coordinate system which does not exist.
$# The specified results are oriented in a system which is unknown to Patran 2013 64-Bit. No user requested transformations or transformations needed for internal processing, such as data averaging, will be performed.
It exists only one coordinate system into the model, coord 0. What is the meaning of these messagges?
