UFunc API for Importing Part into Teamcenter
Is there any UFunc API for importing Part/Assembly into TeamCenter?
I cannot use one under NXOPEN "FileManagementClass" because of constructor unavailable for intializing it in NX 7.5.3, which is fixed in NX 7.5.4 :( as per GTAC.
https://solutions.industrysoftware.automation.siem...
Thanks in Advance,
Prasanna M
RE: UFunc API for Importing Part into Teamcenter
PrasannaNX,
Yes. Here is the beginning of the comments from the header file.
Quote (uf_clone.h)
File Description:
This include file declares routines used for performing clone
operations and clone based PDM Assembly Import and Export
functions. Using these routines you can:
Clone an assembly
Edit an Existing assembly in place
Import an assembly to the PDM system
Export an assembly from the PDM system
HTH,
Joe
