Crack propagation coupled with temperature
In 'Abaqus 6.13',
It is possible to insert a new step after initial. The step-1 can be editted to change the incrementation size, etc..
1-I would like to know which type I need to use when I create 'step-1' in order to study the coupling 'crack propagation/temperature' in a pipe ?
2-Is it appropriate to study a propagating crack with the type 'static,general' in step-1 ?
Thanks.
Thanks.
RE: Crack propagation coupled with temperature
I obtain the following error message:
The following history output requests are applied to XFEM cracks which are not stationary XFEM cracks:
H-Output-1
The Input file was not generated, and the job was not submitted for analysis
ERROR: THIS KEYWORD IS NOT AVAILBLE IN Abaqus/Explicit
LINE IMAGE: *enrichment, name=CRACK-1, type+PROPAGATIONCRACK,
Elset=ASSEMBLY_PICKEDSET6
