NX9 - Code to connect to body attributes?
In a note in NX, <w@TOOL_ID> would automatically fill in the Tool ID once that attribute is set.
What I would like to do, is connect it to attributes of bodies.
Example:
BODY(3) has a STOCK_SIZE attribute of "25MM DIA X 150MM"
I would like to add a code to a note that will fill in the stock size depending on what body you place in the note.
<w@(body(3)STOCK_SIZE> or whatever it would be.
Is this possible?
Example:
Is this possible?
