spring
spring
I am try to produce a spring with a variational sweep I have used a helix curve and then in sketch using on path I have drawn the outside profile of my spring but when I try to use variational sweep
it says the path must be single connected section??? even thou I have sketch on path what am I doing wrong? I have attached a part file of this.
Thank you.
Regards Daniel Lamb
Thank you.
Regards Daniel Lamb
RE: spring
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
