1960's era electical timer relay technology
Have a memory of a timer relay device that consisted of a synchronous motor and a clutch with associated contacts, believe it was manufactured by a company called King of Prussia,(that being the only name stamped on the timer)the device measured about 5 inches X 5 inches X 4 inches and had a dial on the top for altering timing cycles. I can find no technical on-line information, any help appreciated. Need it for retro-fit application.
many thanks in advance.
RE: 1960's era electical timer relay technology
Mike Halloran
Pembroke Pines, FL, USA
this random pdf shows a similar device Link
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Agastat time relays still exist in dieselelectric locomotives. And I think that the spare parts are available in Sweden. At least, those locomotives are maintained nearby.
Gunnar Englund
www.gke.org
