Measure distance in a assembly
When I try to measure a distance between two objects in a assembly with my measure distance tool I can only select one solid because this is the work part but not the other solid? Is there away around this or am I using the wrong measuring tool?
RE: Measure distance in a assembly
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX7.5, NX9.0, NX10.0(Testing)
Vericut7.3.3
www.nxjournaling.com
