Read files .list with matlab
Hi everyone,
I would liko to know how i can read the files with extension .list from ansys adpl program in order to import to matlab and be able to process the results. I need a code of matlab to can do this. It's a bit urgent and i aprecciate a lot the help. Thanks!.
RE: Read files .list with matlab
Yes but it doesn't works well. Besides I have to eliminate some sentences of the file while matlab read it because it has some sentences with '*' and another lines that i don't need to read. I need a code that automatically remove the things I don't want and read me the file properly. Anyway if anyone can help me i will follow trying it. Thans for the response.
Then you probably should have posted this question in the Ansys forum. Or, hire yourself a real Matlab programmer.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
