HIC resistant material
My Current ongoing project is for Gas Development in Indonesia,
For Acid Gas removal unit- Equipment Main Absorber (Column)and flash gas absorber the process licnesor have specified CS+3 mm CA+ PWHT + HIC resistant material ( wet H2S requirement).
The equipment manufacturer have purchased Shell / D’end plates SA 516 Gr 70 N ( HIC tested).
However for pipes and forgings equipment manufacturer mentions these products are considered not sensitive to HIC as long as the Sulfur content complies the maximum limit (seamless & forging product). As per NACE MR-0175
Does this means for forging once the sulfur content is below the 0.025 %, it meets HIC resistant material.
Please clarify
Sebastian
Please clarify
Sebastian
RE: HIC resistant material
http://www.eng-tips.com/viewthread.cfm?qid=336145
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
