Aggregate road base material
Hello
I am working on aggregate road base material for access roads in a project. These roads are meant for a wind project component delivery. The contractor is using KDOT AB-3 material for the aggregate base.
Compaction tests conducted on this material showed OMC 13.5% and MDD 113pcf. We have compaction results from the same site where the native soil (Lean clay) has OMC 15% and MDD 111pcf.
Have you encountered any such materials from your experience in the past. The reason is I am checking other road aggregate materials and they have OMC 6-8% and MDD in the range of 130-140 pcf.
I am wondering if this material could really be used for road construction ? if roads are constructed using such material do they last?
Any input on the range of moisture and MDD for road aggregate materials
Your help is appreciated
NT
NT
RE: Aggregate road base material
Provided the stability requirements (CBR>80) are met, the MDD doesn't mean much except for compaction purposes.
