Cope flange of W14x103 brace?
Are there any set AISC guidelines or rules of thumbs that dictate how much of a beam flange can be removed before a cover plate is needed and what impact the cope will have on axial capacity?
I have a W14x103 brace (have of a V-brace) that will have a slight interference with a large value. One half of the lower flange may need 2-3in removed (the beam flange is ~14in wide). Because the member is a brace it is not subjected to moment. I planned to add a cover plate centered on the beam web with an area greater than the loss in cross sectional area at the flange. Can the impact to axial load capacity be calculated?
RE: Cope flange of W14x103 brace?
1) if this is a special seismic brace and the cope is near a connection meant to yield in out of plane bending, all bets are off.
2) 2-3" on a 14" flange doesn't bother me much. Unless the column is close to it's squash load, I'd probably just ask for the cope to be gently radiussed and leave it at that.
I don't know of any hard and fast requirements. Accurate capacity evaluation is tough. Here's what I'd do:
1) Make sure that you've got enough section left that it won't yield under load. This usually isn't a problem.
2) Figure out where the centre of compressive stress will be where the axial load must pass through the reduced section.
3) Find the eccentricity between the centre of compression at the reduced section and elsewhere.
4) Design the column as a beam column with a kink in it equal to the eccentricity calculated above.
It's interesting to note that, even with cover plating, there may still be eccentricity issues to contend with.
From this:
_______
_______
To This:
_______
_____
Γ
. _______
. _______
To This:
. _______
. _____
. Γ
My first thought would be to ask the ask the mechanical to lower their valve a couple inches!
It's not clear to me how you'd manage that but, if you can, I certainly agree with the approach. And you're quite welcome.
