Material Properties in Attributes
Hello fellow NXers,
I noticed that when I pick a Material for my part in NX8, the Material shows up in the File>Properties Attributes. Is there a way to get the properties of the material, such as density to show up in the attributes?
Thanks as always,
Randy
Thanks as always,
Randy
RE: Material Properties in Attributes
File -> Options -> Save Options...
...and make sure that the 'Generate Weight Data' option is toggled ON.
Now Assign your Material and then save the part file. Now go to...
File -> Properties -> Attributes
...and you should she what you're looking for.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
Thank you,
Randy
