Measurement points on drawings
I am makng a drawing for chrysler and on one of the pages they require me to have measurement points and a table calling out the x,y, and z coordinates. I have made them in the model and have the coordinates. The problem is I need to have the points show up on my drawing so I can have a leader calling out the points. I can see see the points in the model but I cant on the drawing. I have added then to a layer that is visible but they still will not show up.
RE: Measurement points on drawings
www.nxjournaling.com
Yes I am using the master model(assembly) and I do have the points set to the part reference set.
Check that the layer the point objects are on is visible in the drawing view (format -> layer visible in view...).
I am using NX9.0
I have them on a layer that is visible and also I have added the points to the Model Reference set and I still cant see them. Even when I select "Entire Part" I dont see anything.
I can see the measurements points son 3d side and I can't see points on a drawing side,even I can see points on layers setting and made them visible as well.
Pls advise
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
