Fracture propagation coupled with temperature in Pipe
1-I would like to know which feature I need to use in 'step1' in order to study the coupling 'crack propagation/temperature' in a pipe ?
2-Is it appropriate to study a propagating crack with the feature 'static,general' in step1 ?
Thanks.
Thanks.
RE: Fracture propagation coupled with temperature in Pipe
Please re-read your post and think how would anyone who is not you could possibly understand or know what on earth you are on about??
Take some time and explain your question properly and you might get an answer.
It is possible to insert a new step after initial. The step-1 can be editted to change the incrementation size, etc..
1-I would like to know which type I need to use when I create 'step-1' in order to study the coupling 'crack propagation/temperature' in a pipe ?
2-Is it appropriate to study a propagating crack with the type 'static,general' in step-1 ?
Thanks.
Your questions would be better addressed in the FEA Engineering forum.
