ABAQUS - Input file - Definition of nonlinear spring (SPRINGA)
Hello all,
I am currently working at a structural dynamic problem with Abaqus/Explicit. The work involves an impact and in this context the goal is to connect two rigid bodies (with their constraint, mass and velocity field) to each other with a NONLINEAR SPRING; the element used is the so called SPRINGA element.
Using File-->Import-->Model I have imported the input file, which I have previously modified in the following way:
*Spring, elset=SPRING-spring, nonlinear
0,0
1000,0.002481
2000,0.004963
3000,0.007444
4000,0.009926
5000,0.012407
6000,0.014888
7000,0.015062
8000,0.015261
9000,0.015484
*Element, type=SpringA, elset=SPRING-spring
But when I import it in Abaqus, I have the following error:
WARNING: The following keywords/parameters are not yet supported by the input file reader:
*PREPRINT
*SPRING, NONLINEAR
The model "AAA_MODIFY" has been imported from an input file.
Please scroll up to check for error and warning messages.
What did I do wrong? Is the input file correct?
Thank you so much for the help!
RE: ABAQUS - Input file - Definition of nonlinear spring (SPRINGA)
Your syntax looks good.
Abaqus/CAE does not support all abaqus keywords or some of them are supported only with limited options.
Respect to abaqus documentation *SPRING keyword is supported only with ELSET, ORIENTATION, RTOL options.
Full list of supported keywords can find here:
Abaqus/CAE User's Manual, Appendix A: Keyword support
If you have to import your model into Abaqus/CAE you can try use connector elements with nonlinear *CONNECTOR ELASTICIY instead spring elements.
Bartosz
