ug_assy_build utility in Team Center
Hi All,
We want to run ug_assy_build utility in Team center. Can some one suggest the Team Center syntax for this utility.
Thank you in advance.
RE: ug_assy_build utility in Team Center
Ramnx,
The ug_assy_build.exe utility is for unmanaged mode. Creating the assembly using the utility then using "%UGII_BASE_DIR%\ugmananger\ugmananger_clone" to import the assembly is viable a solution.
HTH,
Joe
Jpetach,
Thank you for the answer. Our issue is like this.
We have a list of part numbers. These parts are already exisits in Teamcenter. We need to build an assembly file in Teamcenter with these partnumbers.
Is there any utility or tool for this?
