Recursively scan through product structure (simple program is failing)
I'm a novice programmer but new to CATIA VBA. For a starting program, I'm simply trying to traverse the current product structure and print each part number.
The code runs perfectly as a .CATSCRIPT but when loaded into a CATVBA module, it fails spectacularly.
Run time error 438 'Object doesn't support this property or method' on line 10 ' Analyze (Prod)'
Usually this means your syntax is wrong. VBA seems to have trouble passing Prod as a parameter to the subroutine.
I have verified through debugging that Prod is in fact a VarType 'Product' with a valid assignment.
Nothing I've tried has worked. Any ideas eng-tips? Thanks.
CODE -->
Public Sub CATMain()
    Dim AD As Document
    Dim Prod As Product
    Set AD = CATIA.ActiveDocument
    Set Prod = AD.Product
'    Debug.Print TypeName(AD)
'    Debug.Print VarType(AD)
'    Debug.Print TypeName(Prod)
'    Debug.Print VarType(Prod)
    Analyze (Prod)
End Sub
Public Sub Analyze(P As Product)
    Debug.Print P.PartNumber
    Dim PP As Products
    Dim i As Integer
    i = 0
    Set PP = P.Products
    Do While i < PP.Count
        i = i + 1
        Analyze (PP.Item(i))
    Loop
End Sub
RE: Recursively scan through product structure (simple program is failing)
Try using the CALL keyword in front of the line calling your subroutine in CATMain(). VBA will only use the parenthesis around the arguments when the call keyword is used. I think CATScript ignores this syntax.
--Doug
