difference between
difference between
hi,
am looking for some comparative study Detailed between the tubular heat exchangers and block heat exchangers.
thanks
thanks
RE: difference between
http://www.hcheattransfer.com/selection.html
https://lirias.kuleuven.be/bitstream/123456789/457...
http://www.bre.com/portals/0/technicalarticles/adv...
http://www.chemeng.queensu.ca/courses/CHEE331+332+...
http://www.gea-phe.com/fileadmin/user_upload/docum...
Dejan IVANOVIC
Process Engineer, MSChE
I see that you are new here and I'll give you some unsolicited advice. Ask yourself "why are these guys hanging around eng-tips.com just waiting to give me millions (OK hundreds) of dollars worth of free consulting?" The answer is different for every single one of us, but it is reasonably common for the answer to be "to stretch our minds around unusual or interesting problems". Read your post and see if you think it will engender this interest.
If you had described a problem and discussed what you see as the merits and limitations of shell and tube heat exchangers vs. "block" heat exchangers (whatever that is) then maybe you would have ignited some discussion. Your post as it stands is unlikely to get much response.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
