Robertson Steel Deck
I'm looking for information on Robertson UKX 1-1/2" 18-18 steel decking. The structure I'm working on was built years ago and this is called out on the original drawings. Can anyone point me in the right direction?
RE: Robertson Steel Deck
I might have something about that in my Robertson catalog at home. I can try to check tonight, but it could be on Sliderule's site too. Have you checked that yet? I know someone else in the forum has a Robertson catalog too. You should be able to get some info here soon.
Mike McCann, PE, SE (WA)
If you go under the search tab above your post and enter "Robertson" in the Keyword space, a bunch of prior threads come up. Perhaps one might answer your question.
