NX9 Part Families & Reference sets
If one family member has multiple reference sets needed, but others only need the reference set Home-1, is it possible to create those family members so only the one reference set shows up?
I was hoping there was a way to put a YES or NO under different reference sets like you would for Bodies or Components, but I cant seem to see how that can be done.
In case I am sounding confusing.....
ATB0001 is a tube switch with a Home-1 reference set to show the range at the end.
ATB0002 is a Cube Switch and has 5 reference sets. Each ref set has the range in a different position on the switch.
When we make the family members, ATB0001 will be created with 5 reference sets though only one is needed. The other four are empty and I would like to somehow turn those off from being made in that family member.
