Taking long time while using command Measure Bodies
I am using NX6.0.4.3. It taking long time while using command Measure Bodies almost it is taking 15min.
We observed that it is happening due to changed in customer default as per our requirement. if we do not change customer default, it takes only 15sec. i wants the same result after changing in customer default
Thanking you,
Hitendra
Thanking you,
Hitendra
RE: Taking long time while using command Measure Bodies
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
