Click bottons on an Inputbox of CatiaScript
Good morning,
I've got an issue with CatiaScript.
Is it possible to run a macro and to be ask for click options?
What I mean is, instead of asking for a value that you have to write, ask for one choosen by clicking on it.
Attached screenshots
Picture 1 shows Yes or No bottons, that's what I want but choosing between for example: M1, M2, M3, M4...
Picture 2 shows an example of writting windows.
Picture 1
Your file's link is: http://files.engineering.com/getfile.aspx?folder=4...
Picture 2
Your file's link is: http://files.engineering.com/getfile.aspx?folder=5...
Thank you very much
RE: Click bottons on an Inputbox of CatiaScript
what you're looking for is the child window handler...google that
Eric N.
First observation is that I can't see your attachments. Second, CATScript, catvbs, vbs in general are limited languages, you can't create nice forms with a lot of button unless if you are using inside an hta application (so you can create dynamically another hta and pass back variables - or find another way to work with).
Better try vba (or vb.net) and follow Eric's advice.
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
ok I'll try vba.
Thank you very much
