API 650, Shell Plate Horizontal Weld
Dear Friend,
I have one doubt regarding the Shell Plate Horizontal Weld.
Bottom shell course is 22mm thk and adjacent above shell course is 16mm thk, So my question is if we are chamfer the 22mm plate to 18mm and Weld this 18mm to 16mm with double bevel butt weld. So what will be the chamfer slope?? For double bevel butt weld in this case what angle should maintain for the weld?
Tanks in Advance
Tanks in Advance
RE: API 650, Shell Plate Horizontal Weld
So when we joint(Horizontal) 8mm plate to 6mm plate , Single bevel Butt joint or Square Butt joint which one is better??? API 650 didn't specify the Type of weld.
