Refractory Hex Mesh Forming/ Bending
Hi Everyone,
We need to replace portion of our refractory inside a reactor. For abrasion resistant lining, we are using hex mesh to support the refractory. Access and work area of this section is difficult. A portion of a pipe air distributor located inside the reactor needs lining replacement. My question is,how do you form hex mesh into a pipes' profile? How do you roll or bend hex mesh?
thanks in advance!
thanks in advance!
RE: Refractory Hex Mesh Forming/ Bending
I have bent this on a press brake with a bumping die to form cylinders . But I have never tried to dome it.
B.E.
You are judged not by what you know, but by what you can do.
B.E.
