FREEZE THAW PROTECTION FOR EXPOSED SLAB, JOINTS AND GROUT
I'm working on a project with an exposed mat foundation - 30" thick. It will be subject to freeze thaw cycles. I plan on using 3000 psi w/ 7% AE. I have a few questions on what more I can do to ensure durability.
- Would a concrete sealer be of help for the slab?
- And, I will need some construction joints. Has anyone used PVC water stops (or some other product) to prevent water getting into the joints and causing cracking?
- And how about the grout under base plates. I've seen cases where the exposure has decimated the grout. Is there a solution here? One supplier suggested it is impossible to add Air Entrainment to grout.
RE: FREEZE THAW PROTECTION FOR EXPOSED SLAB, JOINTS AND GROUT
2. Yes have used them. In flatwork they might not be so bad but in vertical applications they were not tied off enough and moved a lot during the pours. We've been told a bead of sika swell in the middle of the joint and then a cant strip of caulking after the forms are removed generally work as well and are easier to do.
3. Talk to sika about this. Their tech department is very knowledgeable and would likely have come across this situation before.
--Winston S. Churchill
The suppliers would rather lose a single small job than get tangled up in a legal battle with owners and contractors. The result is that the higher strengths are common and material cost difference is minimal compared to the cost to deliver concrete a few miles. - For those suppliers that are in both concrete and aggregates, they say that concrete is the most expensive way to sell aggregate considering the plant investment and the extremely high truck costs (purchase, maintenance wages, fuel and scheduling).
Of course, if an engineer specifies a 3000 psi strength for a project they will deliver it and always can monitor the delivery logs (batching weights, batch time, transport time, waiting time and unloading time)in case there is a problem with the concrete. - It is a lot different than when I was working for the local DOT as a concrete inspector when we just grabbed aggregate samples and made cylinders for state projects. That was good summer work for an engineering student considering the long hours and banking overtime to get checks in the fall when I was back in school. It made the 2:00 AM or 4:00 AM starts for large jobs worthwhile.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
