Catia Core & Cavity tool - Main pulling direction definition problem
Hi everyone,
I'm currently trying to use the Main pulling direction definition tool to help me split a model I have. The problem I'm facing is when I try to use this feature I'm getting a completly different menu then the tutorials I've been watching. The feature, when used, only lets me see when my molding joint is but will not split the actual model like in the tutorials. Joined are the pictures of the two menus I'm getting. Respectivly in my own model and then the one in the tutorial videos.
Any help as to why my version of the tool can't seem to split the model would be appriciated. Or else I get I'll just bruteforce it and do it by hand.
Thank you in advance!
http://files.engineering.com/getfile.aspx?folder=4...
http://files.engineering.com/getfile.aspx?folder=3...
PS. I'm using Catia V5 6R2013 SP3 x64
RE: Catia Core & Cavity tool - Main pulling direction definition problem
Win 7
23SP5/24SP3, 3DVIA Composer 2015
