Allowable Bearing Pressure and Settlement
Hi Guys
Structural engineers normally ask for the allowable bearing pressure of the soils. Allowable bearing pressure is then determined by carrying out a bearing capacity analysis and a settlement analysis. The settlement analysis is carried out using the foundation dimensions provided by the structural engineer.
In most cases, the allowable bearing pressure is limited due to the maximum allowable settlement. Once we give the structural engineer the allowable bearing pressure, they tend to start re-sizing the foundation dimensions which affect the settlement predictions, and in some cases this results in further settlement than the maximum allowable settlement.
The trouble I have is, how do I discuss this concept in a geotechnical report? I want to say "The maximum allowable bearing pressure is dependent on the dimensions of the proposed foundations" OR "The maximum allowable bearing pressure of XXX kPa is only applicable to the foundation dimensions provided by the structural engineer at the time of preparation of this report".
Any advice?
SS
Any advice?
SS
RE: Allowable Bearing Pressure and Settlement
You may question how to prepare this chart efficiently. I use an old 1959 ASCE paper SM 4 2135 by B.K.Hough "Compressibility as the Basis of Soil Bearing Value". I believe at lest on State DOT has adopted that method. Can't recall which.
- the next footing should be a certain distance to avoid the overlapping load or
- the heavy column load is used pile.
f-d
ípapß gordo ainÆt no madre flaca!
As to bearing capacity - I never (well, seldom ever) gave a bearing capacity or allowable bearing capacity since, in almost all cases you run into in reality, it is the settlement criteria that will restrict the allowable bearing pressure - to me, capacity is a shear failure issue, pressure is a serviceability issue and the one which almost always rules the roost.
I have read many of the threads related to bearing capacity on this forum. I am really pleased to see that structural engineers have such positive input into the queries.
However, I am not proud to say, that thus far in my career as a geotech, I have worked with many structural engineers who distance themselves in understanding and absorbing the recommendations given by a geotech report, instead all they want to see are numbers which they can plug into their software programs. And its now my understanding that in my country, it would be a rare occasion for a structural engineer to actually grasp the facts and comments that a geotech gives them.
Especially trying to convince them that allowable bearing pressures are, as BigH mentioned, governed by allowable settlement. I have an entertaining path ahead of me.
Thanks Guys!!!
One of the lessons I learned, somewhat the hard way, back then was when a client engineer read my geotech report and then called to say he wondered what bearing capacity he should use for design. There was so much "standard language" in the report that he could not find it. He could care less what different soils were found or how they were found. All he wanted was that one number that was there but buried in the print somewhere. The fancy cover and the beautiful logs didn't impress him. That was even before word processors were available.
Considering the designer is working with maximum loadings that may or may not occur, and the a proximate precision of our reports, going to the extent of the chart I mentioned is rarely needed.
