Journaling question command for number of features in part
Thanks to NXjournaling.com I adapted a program that scans an assembly and gives
for each part or sub assembly the userid from the person who created it. So I could
check easily that my students made it themselves. But students become smarter and
I think they found a trick to fool me.
The answer to the trick is that I can retrieve the number of features or types of
features in the parts.
That is why i am looking for a function that returns the number of feature or
another function that can retrieve strings ( eg. revolve) from Model History in
the part navigator.
Any help is much appreciated.
Olaf
the part navigator.
Olaf
RE: Journaling question command for number of features in part
Here below the code. The red text I added.
This gives me a logging.
Olaf
' Journal to recursively walk through the assembly structure
' will run on assemblies or piece parts
' will step through all components of the displayed part
'NX 7.5, native
'NXJournaling.com February 24, 2012
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module NXJournal
Public theSession As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = theSession.ListingWindow
Sub Main()
Dim workPart As Part = theSession.Parts.Work
Dim dispPart As Part = theSession.Parts.Display
lw.Open
Try
Dim c As ComponentAssembly = dispPart.ComponentAssembly
'to process the work part rather than the display part,
' comment the previous line and uncomment the following line
'Dim c As ComponentAssembly = workPart.ComponentAssembly
if not IsNothing(c.RootComponent) then
'*** insert code to process 'root component' (assembly file)
lw.WriteLine("Assembly: " & c.RootComponent.DisplayName)
lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name)
'ovb top assembly
theSession.Information.DisplayPartHistory(workPart)
'ovb
'*** end of code to process root component
ReportComponentChildren(c.RootComponent, 0)
else
'*** insert code to process piece part
lw.WriteLine("Part has no components")
end if
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
lw.Close
End Sub
Sub reportComponentChildren( ByVal comp As Component, _
ByVal indent As Integer)
For Each child As Component In comp.GetChildren()
'*** insert code to process component or subassembly
lw.WriteLine(New String(" ", indent * 2) & child.DisplayName())
Dim part1 As Part = CType(theSession.Parts.FindObject(child.DisplayName()), Part)
theSession.Information.DisplayPartHistory(part1)
'*** end of code to process component or subassembly
if child.GetChildren.Length <> 0 then
'*** this is a subassembly, add code specific to subassemblies
lw.WriteLine(New String(" ", indent * 2) & _
"* subassembly with " & _
child.GetChildren.Length & " components")
" + Active Arrangement: " & _
child.OwningPart.ComponentAssembly.ActiveArrangement.Name)
'*** end of code to process subassembly
else
'this component has no children (it is a leaf node)
'add any code specific to bottom level components
end if
reportComponentChildren(child, indent + 1)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.Features Module NXJournal Sub Main Dim theSession As Session = Session.GetSession() Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim featArray() As Feature = theSession.Parts.Work.Features.GetFeatures() Dim featEntities() as NXObject lw.WriteLine("*** All Features ***") For each myFeature as Feature in featArray lw.WriteLine(".GetFeatureName: " & myFeature.GetFeatureName) lw.writeline(".Name: " & myFeature.Name) lw.WriteLine(".FeatureType: " & myFeature.FeatureType) lw.WriteLine(".GetType: " & myFeature.GetType.ToString) lw.WriteLine(".Timestamp: " & myFeature.Timestamp.ToString) lw.WriteLine(".Suppressed: " & myFeature.Suppressed.ToString) try lw.writeline(".Location: " & myFeature.Location.ToString) catch ex as nxexception end try lw.writeline("") Next lw.Close End Sub End Modulewww.nxjournaling.com
Thanks, I modified your code to do what I want. But inserting into the main program gives me problems.
It will not run the For Next loop.
Olaf
My modified code:
CODE -->
Option Strict Off Imports System Imports NXOpen Imports NXOpen.Features Module NXJournal Sub Main Dim i as Integer= 0 Dim strMyString As String = " " Dim NameFeature As String = " " Dim Bodystring As string = " " Dim theSession As Session = Session.GetSession() Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim featArray() As Feature = theSession.Parts.Work.Features.GetFeatures() Dim featEntities() as NXObject lw.WriteLine("*** Last Feature ***") For each myFeature as Feature in featArray NameFeature= myFeature.GetFeatureName Bodystring = Mid(Namefeature,1, 4) if bodystring = "Body" then i= i+1 end if strMyString = myFeature.Timestamp.ToString Next lw.WriteLine(".Timestamp: " & strMyString & " " & NameFeature) if i > 0 then lw.WriteLine("Number of bodies: " & i ) end if lw.Close End Sub End ModuleRE: Journaling question command for number of features in part
I adapted the program a little but in my test assembly, only twice the features are listed (really once because the part is used two times).
The code is, bold is where I am working on :
Assembly is attached window_frame_assembly.prt is top assembly.
Olaf
CODE
' Journal to recursively walk through the assembly structure ' will run on assemblies or piece parts ' will step through all components of the displayed part 'NX 7.5, native 'NXJournaling.com February 24, 2012 Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpen.Assemblies Imports NXOpen.features Module NXJournal Public theSession As Session = Session.GetSession() Public ufs As UFSession = UFSession.GetUFSession() Public lw As ListingWindow = theSession.ListingWindow Sub Main() Dim workPart As Part = theSession.Parts.Work Dim dispPart As Part = theSession.Parts.Display lw.Open Try 'Dim c As ComponentAssembly = dispPart.ComponentAssembly 'to process the work part rather than the display part, ' comment the previous line and uncomment the following line Dim c As ComponentAssembly = workPart.ComponentAssembly if not IsNothing(c.RootComponent) then '*** insert code to process 'root component' (assembly file) lw.WriteLine("Assembly: " & c.RootComponent.DisplayName) lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name) 'ovb top assembly lw.writeline("top asm "& workpart.tostring) ' theSession.Information.DisplayPartHistory(workPart) 'ovb '*** end of code to process root component ReportComponentChildren(c.RootComponent, 0) else '*** insert code to process piece part lw.WriteLine("Part has no components") end if Catch e As Exception theSession.ListingWindow.WriteLine("Failed: " & e.ToString) End Try lw.Close End Sub '********************************************************** Sub reportComponentChildren( ByVal comp As Component, _ ByVal indent As Integer) dim namefeature as string = " " For Each child As Component In comp.GetChildren() '*** insert code to process component or subassembly lw.WriteLine(New String("1", indent * 2) & child.DisplayName()) Dim part1 As Part = CType(theSession.Parts.FindObject(child.DisplayName()), Part) lw.writeline("part 2 "& part1.tostring) 'theSession.Information.DisplayPartHistory(part1) lw.writeline("comp 3 : "& comp.tostring) dim pls1 as PartLoadStatus thesession.parts.setworkcomponent(comp, pls1) dim farray() as feature = thesession.parts.work.features.getfeatures() lw.writeline(" features!!! from " & comp.tostring) for each myfeature as feature in farray namefeature=myfeature.getfeaturename lw.writeline(" " & Namefeature) next '*** end of code to process component or subassembly if child.GetChildren.Length <> 0 then '*** this is a subassembly, add code specific to subassemblies lw.WriteLine(New String("4", indent * 2) & _ "* subassembly with " & _ child.GetChildren.Length & " components") lw.WriteLine(New String("5", indent * 2) & _ " + Active Arrangement: " & _ child.OwningPart.ComponentAssembly.ActiveArrangement.Name) '*** end of code to process subassembly else 'this component has no children (it is a leaf node) 'add any code specific to bottom level components end if reportComponentChildren(child, indent + 1) Next End Sub '********************************************************** Public Function GetUnloadOption(ByVal dummy As String) As Integer Return Session.LibraryUnloadOption.Immediately End Function '********************************************************** End ModuleRE: Journaling question command for number of features in part
Try this version:
CODE
' Journal to recursively walk through the assembly structure ' will run on assemblies or piece parts ' will step through all components of the displayed part 'NX 7.5, native 'NXJournaling.com February 24, 2012 Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpen.Assemblies Imports NXOpen.features Module NXJournal Public theSession As Session = Session.GetSession() Public ufs As UFSession = UFSession.GetUFSession() Public lw As ListingWindow = theSession.ListingWindow Sub Main() Dim workPart As Part = theSession.Parts.Work Dim dispPart As Part = theSession.Parts.Display lw.Open Try 'Dim c As ComponentAssembly = dispPart.ComponentAssembly 'to process the work part rather than the display part, ' comment the previous line and uncomment the following line Dim c As ComponentAssembly = workPart.ComponentAssembly if not IsNothing(c.RootComponent) then '*** insert code to process 'root component' (assembly file) lw.WriteLine("Assembly: " & c.RootComponent.DisplayName) lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name) 'ovb top assembly lw.writeline("top asm " & workpart.leaf) ' theSession.Information.DisplayPartHistory(workPart) 'ovb '*** end of code to process root component lw.writeline("") ReportComponentChildren(c.RootComponent, 0) else '*** insert code to process piece part lw.WriteLine("Part has no components") end if Catch e As Exception theSession.ListingWindow.WriteLine("Failed: " & e.ToString) End Try lw.Close End Sub '********************************************************** Sub reportComponentChildren( ByVal comp As Component, _ ByVal indent As Integer) dim namefeature as string = " " For Each child As Component In comp.GetChildren() '*** insert code to process component or subassembly 'lw.WriteLine(New String("1", indent * 2) & child.DisplayName()) lw.WriteLine(child.DisplayName()) 'Dim part1 As Part = CType(theSession.Parts.FindObject(child.DisplayName()), Part) Dim part1 as Part = child.Prototype.OwningPart lw.writeline("part1: "& part1.leaf) 'theSession.Information.DisplayPartHistory(part1) lw.writeline("comp: "& comp.displayname) dim pls1 as PartLoadStatus thesession.parts.setworkcomponent(child, pls1) dim farray() as feature = thesession.parts.work.features.getfeatures() lw.writeline(" features!!! from " & child.displayname) for each myfeature as feature in farray namefeature=myfeature.getfeaturename lw.writeline(" " & Namefeature) next '*** end of code to process component or subassembly if child.GetChildren.Length <> 0 then '*** this is a subassembly, add code specific to subassemblies lw.WriteLine("* subassembly with " & _ child.GetChildren.Length & " components") lw.WriteLine(" + Active Arrangement: " & _ child.OwningPart.ComponentAssembly.ActiveArrangement.Name) '*** end of code to process subassembly else 'this component has no children (it is a leaf node) 'add any code specific to bottom level components end if lw.writeline("") reportComponentChildren(child, indent + 1) Next End Sub '********************************************************** Public Function GetUnloadOption(ByVal dummy As String) As Integer Return Session.LibraryUnloadOption.Immediately End Function '********************************************************** End Modulewww.nxjournaling.com
Thanks, thanks!!!!!!
The code has become the following.
I am still testing.
But I found a caveat in the code.
In NX7554 the code runs correctly when the assembly is partially loaded, in NX10.01 the code
runs not correctly until all parts are loaded. Strange!!!
Many thanks for your time and help!!
Olaf
CODE
' Journal to recursively walk through the assembly structure ' will run on assemblies or piece parts ' will step through all components of the displayed part 'NX 7.5, native 'NXJournaling.com February 24, 2012 Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpen.Assemblies Imports NXOpen.features Module NXJournal Public theSession As Session = Session.GetSession() Public ufs As UFSession = UFSession.GetUFSession() Public lw As ListingWindow = theSession.ListingWindow Sub Main() Dim workPart As Part = theSession.Parts.Work Dim dispPart As Part = theSession.Parts.Display lw.Open Try 'Dim c As ComponentAssembly = dispPart.ComponentAssembly 'to process the work part rather than the display part, ' comment the previous line and uncomment the following line Dim c As ComponentAssembly = workPart.ComponentAssembly if not IsNothing(c.RootComponent) then '*** insert code to process 'root component' (assembly file) lw.WriteLine("Assembly: " & c.RootComponent.DisplayName) lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name) 'ovb top assembly lw.writeline("top asm " & workpart.leaf) theSession.Information.DisplayPartHistory(workPart) 'ovb '*** end of code to process root component lw.writeline("") ReportComponentChildren(c.RootComponent, 0) else '*** insert code to process piece part lw.WriteLine("Part has no components") end if Catch e As Exception theSession.ListingWindow.WriteLine("Failed: " & e.ToString) End Try lw.Close End Sub '********************************************************** Sub reportComponentChildren( ByVal comp As Component, _ ByVal indent As Integer) dim namefeature as string = " " dim test as string = " " dim strMyString as string = " " dim Bodystring as string = " " dim i as integer = 0 dim j as integer = 0 For Each child As Component In comp.GetChildren() '*** insert code to process component or subassembly 'lw.WriteLine(New String("1", indent * 2) & child.DisplayName()) 'lw.WriteLine(child.DisplayName()) 'Dim part1 As Part = CType(theSession.Parts.FindObject(child.DisplayName()), Part) Dim part1 as Part = child.Prototype.OwningPart 'lw.writeline("part1: "& part1.leaf) 'theSession.Information.DisplayPartHistory(part1) 'lw.writeline("comp: "& comp.displayname) dim pls1 as PartLoadStatus '*** make work part thesession.parts.setworkcomponent(child, pls1) dim farray() as feature = thesession.parts.work.features.getfeatures() '*** test of work part is a part starting with Hex Par Dis indicating library element to be skipped for processing test= left(part1.leaf.tostring,3) select case test case "Hex" lw.writeline("bout") case "Par" lw.writeline("cilindrische pen") case "Dis" lw.writeline("onderleg ring") case Else lw.writeline("Part met volgende features: "& part1.leaf) 'lw.writeline(" features!!! from " & child.displayname) for each myfeature as feature in farray namefeature=myfeature.getfeaturename 'lw.writeline(" each lus namefeature :" & namefeature) Bodystring = " " Bodystring = Mid(Namefeature,1, 4) if Bodystring = "Body" then i= i+1 'lw.WriteLine("In lus each: " & i) end if if Bodystring = "soli" then j= j+1 'lw.WriteLine("In lus each: " & j) end if 'lw.writeline(" " & Namefeature) strMyString = myFeature.Timestamp.ToString next lw.writeline(" ") lw.WriteLine(" " & strMyString & " " & NameFeature) lw.writeline(" ") theSession.Information.DisplayPartHistory(part1) lw.writeline(" ") if i > 0 then lw.WriteLine("Number of bodies: " & i & " bodies bodies bodies!!!!!!!!" ) end if if j > 0 then lw.WriteLine("Number of solids: " & j & " solids solids solids!!!!!!!!" ) end if i=0 j=0 lw.WriteLine(".Timestamp: " & strMyString & " " & NameFeature & " " & part1.leaf ) lw.writeline(" ") end select '*** end of code to process component or subassembly if child.GetChildren.Length <> 0 then '*** this is a subassembly, add code specific to subassemblies lw.WriteLine("* subassembly with " & _ child.GetChildren.Length & " components") lw.WriteLine(" + Active Arrangement: " & _ child.OwningPart.ComponentAssembly.ActiveArrangement.Name) '*** end of code to process subassembly else 'this component has no children (it is a leaf node) 'add any code specific to bottom level components end if lw.writeline("") reportComponentChildren(child, indent + 1) Next End Sub '********************************************************** Public Function GetUnloadOption(ByVal dummy As String) As Integer Return Session.LibraryUnloadOption.Immediately End Function '********************************************************** End ModuleRE: Journaling question command for number of features in part
CODE
Private Function LoadComponent(ByVal theComponent As Component) As Boolean Dim Sess as Session = Session.GetSession() Dim ufs as UfSession = UfSession.GetUfSession() Dim thePart As Part = theComponent.Prototype.OwningPart Dim partName As String = "" Dim refsetName As String = "" Dim instanceName As String = "" Dim origin(2) As Double Dim csysMatrix(8) As Double Dim transform(3, 3) As Double Try If thePart.IsFullyLoaded Then 'component is fully loaded Else 'component is partially loaded End If Return True Catch ex As NullReferenceException 'component is not loaded Try Sess.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform) Dim theLoadStatus As PartLoadStatus Sess.Parts.Open(partName, theLoadStatus) If theLoadStatus.NumberUnloadedParts > 0 Then Dim allReadOnly As Boolean = True For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1 If theLoadStatus.GetStatus(i) = 641058 Then 'read-only warning, file loaded ok Else '641044: file not found allReadOnly = False End If Next If allReadOnly Then Return True Else 'warnings other than read-only... Return False End If Else Return True End If Catch ex2 As NXException If ex2.Message.ToLower = "file not found" Then 'code for "file not found" condition End If Return False End Try Catch ex As NXException 'unexpected error Return False End Try End Functionwww.nxjournaling.com
