Curvature definition in Solidworks
Hi~
I am using Solidworks and CATIA.
CATIA provides Gaussian curvature and mean curvature for surface analysis.
However, I can not find out which surface curvature is provided in Solidworks.
Is it Gaussian curvature, mean curvature, minimum curvature, or other definition?
In the HELP documents, I only found "Curvature is defined as the reciprocal of the radius (1/radius), in current model units. By default, the greatest curvature value displayed is 1.0000, and the smallest value is 0.0010."
Can you kindly help me? Thank you!
RE: Curvature definition in Solidworks
Pretty sure it's minimum curvature. If you're intrepid, you can make some models to test this. If you're not, you can simply take my words.
Intrepid, had to look it up - good one Tick. Not that I have a clue how that curvature really works, but it sounds like it fits with tongue-in-cheek.
Design for RELIABILITY, manufacturability, and maintainability
