NX 9.0 Drafting - No Expand Nor View Dependent Edit
I have a file that, in drafting mode, does not give me an "Expand" nor "View Dependent Option". I did a save as, and the original and the saved as files have the same issue. How do I make these two options available? I have no issue with the other components in the assembly on have these options, just this file.
RE: NX 9.0 Drafting - No Expand Nor View Dependent Edit
www.nxjournaling.com
then you will able to do what you want just like any other view
