Tool Steel For Piercing Die with high tensile strength after heat treatment
I need to specify a die for a piercing operation which needs to have a high tensile strength, probably around 1000 mpa if possible and yet still be sufficiently hard to give a reasonable life in terms of retaining its sharp edge. Anybody out there with any suggestions?
RE: Tool Steel For Piercing Die with high tensile strength after heat treatment
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
