Saturation of the sample at triaxial test
I am doing CU triaxial test on silty sand sample ( sand + 40% low plastic fine content ), I faced with a problem in saturation phase.
I let the Co2 gas goin through the sample about 1 hour then using deaired water, but after 1 day waiting the water does not
move through the sample any more, also I have used cell pressure 2.5 bar and back pressure 2 bar to remove the rest gas in voids, but the sample would not fully saturate.
Would you please suggest me to find the best solution for this problem?
RE: Saturation of the sample at triaxial test
How much your B-value? if it is equal or more than 0.95. That should be ok.
I agree wtih L0k, if the B-value is 0.95, you're there. A B-value of 0.95 does not correlate to 95 percent saturation, it's greater.
f-d
ípapß gordo ainÆt no madre flaca!
