Welding schedule
Welding schedule
Dear Tank Builders,
This should be Welding Engineer scope of Work.
But I would like to know of there is any quick reference about how many passes to weld bottom plate A 283 C / A 36 9 mm thick ? Each pass should be xx mm electrode and EXXXXX of electrode. Let say for 9 mm plate the root pass 2.4 mm E 6012 then 3.2 mm filler then 3.2 mm capping.
Thanks for any comments.
RE: Welding schedule
Typically, one pass of 7024 5/32" 4mm [or larger] for floor-to-floor lap welds. Thus the mandatory Vacuum Box testing of the floor welds.
