fault current
fault current
fault current
Hello everyone ,
my question is about the fault current occured by a short circuit on a hight voltage line, i want to know, which parameters influence on this fault currect, is it the line distance or the line impedance or maybe it's neither one nor the other, i'm really confused.
Thank you for answering me.
RE: fault current
Source impedance, line impedance, fault impedance. Generally, in a transmission system you will have two source impedances and two line impedances in parallel.
