Assigning each part a position in space
Hello all,
I would like to ask you if it's possible in abaqus to assign a part X,Y,Z coordinates so that no movements are to be made when assembling. I'm trying to use the keyword way of doing things, and the solids I'm "Stacking" are rectangular.
Thank you in advance.
RE: Assigning each part a position in space
In CAE that's not possible. You would have to create the parts directly at the correct location.
With the keywords you can check if *System could help.
