Native Product Template Studio
I have a following problem with PTS , I have set up a Teamcenter configuration but unfortunately it does not work, but in this stage I can not start it in native mode neither. Is there a config file to reset the settings?
On my computer there is 3 NX ( 6, 8.5, 9). I have changed only the NX 8.5 settings but now I can not start all of them. It must be a central config file.
I don´t want to re-install the NX.
Thank you in advance
RE: Native Product Template Studio
Does yours open? If it does, does it mention Java as an issue?
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
There is a pts_properties.xml file under c:\users\<log in name>
If you delete that file, then PTS will go back to defaulting to native mode.
