Copy coordinate system
Is there any way to copy or use the coordinate systems created in the part or assembly module? In the visualization module, they do not show.
Ultimately I want to transform the stress results to local coordinate system I made in part module
RE: Copy coordinate system
Yes, I can create another coordinate system in the Visualisation module but that gets a bit tedious each time you tweak the model and run the job again. Thus far all the coordinate systems I have created in the assembly module to appear in the final results.
