how to Set Transparency in NX Solid model Using KF?
RE: how to Set Transparency in NX Solid model Using KF?
Hello @ragutz2,
Some time ago I've create this code, changing journal for colour face. I don't know what is knowledge fusion, but maybe it will work for You.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module changeColorOfPreSelectedFaces_v2
    Dim theSession As Session = Session.GetSession()
    Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
    Sub Main()
        '' The selectFaces method takes an NXobject array by reference
        Dim selectedObjectsArray() As NXObject
        Selectbody(selectedObjectsArray)
        '' Need to recast the face NXObjects to Displayable objects
        Dim faceArray(selectedObjectsArray.Length - 1) As DisplayableObject
        For i As Integer = 0 To selectedObjectsArray.Length - 1
            faceArray(i) = CType(selectedObjectsArray(i), DisplayableObject)
        Next
        Dim changeBodytransluency As DisplayModification = theSession.DisplayManager.NewDisplayModification()
        With changeBodytransluency
            .ApplyToAllFaces = true
            .NewTranslucency = 40
            .Apply(faceArray)
            .Dispose()
        End With
    End Sub
    Sub Selectbody(ByRef selectedObjects As NXObject())
        Dim ui As UI = NXOpen.UI.GetUI
        Dim message As String = "Select body"
        Dim title As String = "Selection"
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim keepHighlighted As Boolean = False
        Dim includeFeatures As Boolean = False
        Dim response As Selection.Response
        Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(1) As Selection.MaskTriple
	With selectionMask_array(0)
            .Type = UFConstants.UF_component_type
            .Subtype = UFConstants.UF_component_subtype
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
        End With
        With selectionMask_array(1)
            .Type = UFConstants.UF_solid_type
            .Subtype = 0
	End with
        response = ui.SelectionManager.SelectObjects(message, title, scope, _
                                         selectionAction, includeFeatures, _
                                     keepHighlighted, selectionMask_array, _
                                                      selectedObjects)
        If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
            Return
        End If
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
    End Function
End Module
I have find out, that this code have one disadvantage, it work perfect in part, but sometimes doesn't work in assembly, and I don't have idea why.
In line:
CODE
I set translucency for 40 percent.
With best regards
Michael
Niedzviedz I will try your approach.
Thanks and Regards!
