Brigde Crane calculation
I posted this thread in the electric motor forum but got none replies so I am posting it again here. Thanks!
I need to calculate the electric motor and speed reducer for a small bridge crane. Its been very long since I have done this type of work and I not sure how to do it
Max crane load will be 2500 kg
Bridge crane weight 500 kg aprox
Number of wheels 4
Wheel diameter 132 mm
Speed 0,3 m/s
The motor and reducer will move with a chain drive a long shaft (5 meters) that connects 2 of the wheels
Any help please?
lukin1977
RE: Brigde Crane calculation
lukin1977,
This is not a clear question. What does the motor do? What allows the motor to lift stuff?
JHG
He's clearly talking about the motor that drives the crane bridge along the runway. There is a separate motor for lifting.
I think basically you have to decide how big a piece of dirt the wheels have to ride over.
... or just look in anyone's catalog and use that number.
Mike Halloran
Pembroke Pines, FL, USA
The motor is for driving the crane on the railway.
Mike: I dont understand your comment about the piece of dirt. Could you explain?
Occupant: Why didn´t you add the crane´s weight to the load?
Load = 2500+500 = 3000 kgf = 29419,95 N
wheel rpm = v/r = 0,3x2/0,132 = 4,54 rad/s = 43,14 rpm
i= motor rpm/wheel rpm = 1745/43.14 = 40,2
Friction force = Load x Us
Torque = Friction force x wheel diam /2 = Load x Us x wheel diam/ 2 Us = static friction coeff for steel = 0,4
Torque = 29419,95 x 0,4 x 0,132/ 2= 776,68 N.m
motor torque = 776,68 / 40,2 = 19,32 N.m
motor Power = 19,32 x 1745 x 0,1047 = 3529,89 W
3,5 kW seems too big to me
what am I missing?
the two motorized wheels do not have a bearing of 50 mm. They have a keyed shaft
the remaining two wheels have a bronze bearing diameter 30 mm
Then the keyed shaft has bearings. I just selected 50mm bronze bushings because you didn't specify and if they are ball bearings, you'll have to adjust the coefficient of friction.
