Using OpenOffice with NX?
Can Open Office be used with NX 9?
The answer back in 2008 was no.
http://www.eng-tips.com/viewthread.cfm?qid=232171
Has that changed?
The reason I ask is our IT department loaded a new work station with Open Office instead of Excel. I just wanted confirmation before more time is wasted trying to find a work around.
Thank you
Ken.
Has that changed?
Thank you
Ken.
RE: Using OpenOffice with NX?
Ben Loosli
I'm am guessing not, due to the lack of instructions on the matter within the UG Docs.
I don't want to approach our IT guy and say this must be loaded with Excel, without knowing for sure.
Thank you for the replies.
http://www.gmfile.net/soft/windows/business/office...
or, http://freecode.com/projects/xess. I would scan and check the file before installing from this site.
If you look at the Spreadsheet Preferences, there is an option of either XESS or Excel. I have never used XESS, but if you call GTAC, I am sure they will assist you in configuring your UG to XESS.
