2015 NX Workstation recommendation
Greetings All,
My company is going to be purchasing new workstations very soon. These will be running NX 9, Teamcenter 10 and some will be used for FactoryCAD and Process Simulate. We've been buying the Dell T3610 but those are being phased out. We prefer Dell workstations. Currently considering the Dell 7810. We have the option of ordering dual processors but we're leaning toward a single 8 core Xeon processor. Are there any big advantages to a dual processor setup for NX 9. I'm hoping someone can chime in here. An 8 core Xeon is pretty beefy. Any advice would be appreciated.
Thanks!
Thanks!
RE: 2015 NX Workstation recommendation
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ben Loosli
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
It also can depend on your motherboard which chip configuration is better. Anyway two quad cores can have an advantage because the cpu cache and the ram channels are doubled. But I don't think the average person can tell the difference, especially running NX. Probably the best upgrade for the money would be an SSD drive, everybody can tell the difference.
www.nxjournaling.com
In the beginning this was limited to only the Parasolid kenel, but over the years more SMP support has been added to both Parasolid as well as selected NX processes. As mentioned previously, CAM has recently introduced some opportunities to utilize more than single core configurations. Also, when we added the built-in 'movie' capture function to NX, that takes advantage of a secondary core. And while it is true that NX itself can only take use up to four cores, additional cores will allow other applications to run on your system without having a big impact on NX. Also note that NX Nastran can take advantage of more than four cores. Depending on how the Nastran solver is set-up, it can spread a analysis run over as many as 128 cores at once.
So the bottom line, get at least four cores if all you're running is NX, and more cores if NX is only one of the primary applications that might be running or is you intend to do any sort of structural analysis (CAE/FEM) type work.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I think that the single 8 core Xeon E5-2630 v3 (8C, 2.4GHz, Turbo, HT, 20M, 85W)is the wrong choice, look for something with a higher clock speed and less cores.
I'd suggest the Intel® Xeon® Processor E5-1630 v3 (10M Cache, 3.70 GHz) or Intel® Xeon® Processor E5-2637 v3 (15M Cache, 3.50 GHz), which are both 4 core
I have just seen an HP z620 that was brought for NX Cam with a 6 Core 2.4Ghz Xeon have to be replaced because it was slow compared to a 4 year old Z400
Also look at as much RAM as possible. and how it is configured (4 x 4gb may be better than 1x16 or 2x8 depending on the motherboard used)
I'm currently running a Z620
2x Intel® Xeon® Processor E5-2637 v2 (15M Cache, 3.50 GHz)
Quadro K4000
32GB RAM (4x4 on MB 4x4 on the 2 processor riser card)
256gb SSD.
I'm my case the K4000 Card works really fell running 2 27" screens, not sure if the K5200 would give any real advantage unless your doing a lot of rendering or are thinking of 4K screens ?
If I was to replace this today I would look at the newer V3 Processor the K4200 and a bigger SSD
Slow down there, my metallic friend...
NX modeling can use up to 4 cores for certain tasks (e.g. booleans, movie capture, some display operations, etc), it will not utilize multiple cores for everything.
Looks this is using only a single core/thread.
To me, the better is looking for fastest raw power single thread CPU. (Highest clockspeed/Cache, but this is not always true)
"My english is bad ? That's why i'am french."
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
When a piece of software crashes, particularly something like NX, which has a reputation for being VERY stable, avoiding the one organization formally charged with helping people in situations like that and which BTW, your maintenance dollars are paying for, is simply naive at best. If you feel that you're not getting the service that you PAID for, ask that your problem be escalated. Demand to speak to a supervisor or a manager. From my experience when dealing with our customers, moat of them are very happy with their relationship with and the effectiveness of our customer support organization, of which GTAC plays a central and critical role.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I have also had numerous contact with a Massachusetts CAD vendor. Calls are almost always answered first by a ESL person who is working a shift 12 hours off from your own. Numerous call backs, sometimes escalation is tyhe only way to get an answer. I have had to email the director of customer service because I was so frustrated with the way my call was being handled.
Give me GTAC any day of the week over the other comapny's support!!!
Ben Loosli
my experience with gtac is, that it HIGHLY depends on the person. For some persons you know that they do everything to give you the best help. in this time I am satisfied although the real solution may be 2 or more major version in the future.
But sometimes you can read between every line that he does want/can not help you...
Many times they try to tell me that I am the first one who gets this error (seriously?)
But my opinion is like John R Baker said: The only ways we have is to make calls. It is better than everything. And over the years I found many talended and motivated supporters. Unfortunately I cannot choose but have to pray that the right person takes the call.
The first lesson I have learned: always write in english! because a wider group of supporters can take the call and they do not have to translate everything for hand over to development...
We're upgrading from T3610s and are looking at the T5810 (ES-1660v3 3GHz 8C, 16GB DDR4 ECC RAM, Quadro K4200 GPU). We are at a question about going the 15K SAS or a SSD (Samsung 850Pro) for performance.
We are even questioning weather we move to dual GPUs and how to that might impact performance. Also, how to configure them using the Quadro Sync card.
One of our Engineering users is suggesting we move down to the ES-1650v3 card which is only 6C but 3.5Ghz clock. With the way they use the UG sessions, sometimes opening 4-5 at a time, I think they would see better performance from the 8C model...thoughts?
-M Carson
Windsor Mold Group
Windsor, ON
Xeon E5-1650 v2 @ 3.5GHz (6 Cores)
NVIDIA Quadro K5000
16GB DDR3 RAM (1866MHz & 4x4GB)
256GB SSD (Boot & Working)
1TB Platter (Secondary)
