Concrete Design Software - Unified Model
My experience with concrete buildings & software is having separate models (and software) for slabs, columns, and lateral. Usually slabs in Safe or Concept, lateral in Etabs, and then design of walls and columns in some standalone program (similar for foundations).
I see Adapt advertising 'Edge' and CSC with 'Orion' as complete unified model solutions - slabs, lateral systems, columns, footings etc. This would be great if it worked well, curious if anyone is using this and it's working out.
RE: Concrete Design Software - Unified Model
I have some excel setups that do mini versions of this - for example for column loads and designs to reach out and grab safe output files. But this is still a lot of work and requires making sure that all the various models are correct.
Seems like a unified model will eventually come, just curious how close these guys are getting now. I'm wondering how they break apart lateral from gravity when for most situations you are not counting slab stiffness in your lateral model, and the variations in base modeling etc. for lateral vs gravity. Also curious if they stage the loading somehow, otherwise full models show much different load distribution than individual models because of the greater shortening at cols vs walls etc. Would be really nice if it was all worked out. Maybe I'll test drive a trial version.
Eh... not quite so fancy. We're making algorithms so that you can point to a Revit model and have it create an ETABS model etc. If you know the API well enough, this can be done quite robustly. Also, it seems that the various software vendors are gradually moving towards a common format. Kind of like ASCII for structural software.
I think that part of what holds back a unified software package is that, in truth, we might not really want it in our heart of hearts. The simplifications that we take to use the separate packages often speed up design and detailing even if they slow down model creation and analysis. Once we finally have a single model that accounts for gravity, lateral, temperature, column shortening, and construction sequencing... will we actually want it? I do on an academic level for sure. From a productivity standpoint, I'm not so sure.
Thanks in advance
