VERTICAL GAS-LIQUID SEPARATOR TANGENTIAL INLET NOZZLE
Do we need a wear plate inside a separator when using a tangential inlet ? if yes, where to install it with respect to the inlet ? since the flow pattern is along the perimeter and not "against" the separator wall may be the wear plate is not required.
Please advise your opinion, the fluid is air with a small amount of water.
regards,
roker
regards,
roker
RE: VERTICAL GAS-LIQUID SEPARATOR TANGENTIAL INLET NOZZLE
Cheers,
gr2vessels
"Three Phase Separators - Inlet devices" by Saeid Rahimi
