Flatness Callout Question
I have never seen flatness this way on any of my prints. I assume it means a flatness of .0010 across the entire area and no worse of a flatness of .0005 in a 1mm x 1mm area? Yes the print is in metric. Any help on interpretation? Thanks!
________________________________
Ryan M
Quality Engineer
3d Printer Hobbyist
RE: Flatness Callout Question
Wow, just wow.
Out of curiosity, what made you think it was flatness?
Much better now.
Your guess is correct, and also (F) means "free state"
The numbers look a bit uncomfortable; are you sure this is metric?
100% positive :) I wont dare say how wide this plate is. Trust me it is a bit ridiculous, these are precision ground ceramics, holding sub-micron or millionths of an inch of flatness happens now and then, just not normally over this size, and I have never seen it called out this way. Usually my print will just say flat to "x" number of helium light bands or something like that.
Ryan M
Quality Engineer
3d Printer Hobbyist
If you can't do it then no quote it. Nothing pisses me off more than getting a quote for a part, giving a purchase order and then the supplier comes back with exceptions. Just this week I got a call from a supplier who we have been working with for over a year asking what the tolerance is on a part with a profile of a surface call out. They are supposed to supply PPAP this week and they are just getting around to figuring out the print?!?!?!?
Here, here. Agree. What's the point of quoting a part if you can't actually do what the specifications on the print say? (Boggles my mind.)
SW Professional 2014 SP 5.0
SW Electrical 2D/3D SP 5.0
64 bit
Intel Xeon X(R) CPU 1603 0 @ 2.80 GHz
8.0 GB of RAM
NVIDIA Quadro 2000
I definitely agree with you. And we do have the capability, material, and measuring equipment. I had never seen the flatness callout with 2 values and never one that has something like the "1x1" next to it. Millionths of an inch, no problem. By best part is .000006 flat.
Ryan M
Quality Engineer
3d Printer Hobbyist
In a case like this, if you're capable of meeting the drawing specs, then I'd quote what it would take...but include a indicating that the price would drop by X amount if they could live with Y flatness tolerance. That's a polite way of questioning whether they really, really need it that flat (maybe they do, or maybe someone made a mistake).
