Modelling of bicycle suspension
Hey,
so as part of my third year university project we have to design and build a folding bicycle, as part of this process we have to show some form of FEA analysis. I have done one module in abaqus that really didn't prepare me for what I needed to model a complete 3D FEA analysis and as such I have taught myself through what was available online and trial and error. I have now got a running model in place that gives results, however I feel that the deflection represented by the model is considerably larger than what it really ought to be.
Here is the frame before deformation is plotted: Link
And the frame after deformation is plotted: Link
The frame has been imported from solidworks in several parts and all interactions between parts should be correct. The spring itself is modelled as a 75mm 550 lbs/in spring mounted between two aluminium blocks to simulated a normal bicycle suspension spring.
Any help in this would be greatly appreciated and I apologize if this is not the correct way of showing screenshots on this forum, it's my first time posting.
Kind regards,
Adam
Kind regards,
Adam
RE: Modelling of bicycle suspension
Kind regards,
Adam
Do you have consistent units? Your spring definition was stated as "75mm 550 lbs/in"
When viewing results Abaqus can scale the deformation. Make sure it's set to 1 if you want to see the actual deformation.
I hope this helps.
Rob Stupplebeen
www.optimaldevice.com
https://sites.google.com/site/robertkstupplebeen/
As for the viewer scaling, I wasn't aware if that was something that could be altered, as I mentioned I have been teaching myself through mostly trial and error so a lot of what is probably basic and silly things are over my head still. How would I go about changing the viewer scaling? I've looked through all the settings and can't seem to spot in anywhere.
Thanks for the quick responses.
