Custom plate washer to increase Appendix D capacity
On appendix D, the ANC is calculated from the center of the bolt. If I add a thick custom washer, is there a way to increase this number? I feel like my ANC should be higher? Does Appendix D cover this anywhere?
RE: Custom plate washer to increase Appendix D capacity
You will have to excavate a pocket around the head of the anchor to provide adequate concrete corrosion cover. But this way, you can avoid App D altogether.
