nusselt number
nusselt number
why in nusselt number the lenght not thickness is used... Like we take thickness perpendicular to the direction in which heat is transferred but why not in nusselt no
RE: nusselt number
RE: nusselt number
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
RE: nusselt number
'The convection and conduction heat flows are parallel to each other and to the surface normal of the boundary surface, and are all perpendicular to the mean fluid flow in the simple case.
Nu = hL/k
where L is the characteristic length, k is the thermal conductivity of the fluid, h is the convective heat transfer coefficient of the fluid.
Selection of the characteristic length should be in the direction of growth (or thickness) of the boundary layer; some examples of characteristic length are: the outer diameter of a cylinder in (external) cross flow (perpendicular to the cylinder axis), the length of a vertical plate undergoing natural convection, or the diameter of a sphere. For complex shapes, the length may be defined as the volume of the fluid body divided by the surface area.
The thermal conductivity of the fluid is typically (but not always) evaluated at the film temperature, which for engineering purposes may be calculated as the mean-average of the bulk fluid temperature and wall surface temperature.
In contrast to the definition given above, known as average Nusselt number, local Nusselt number is defined by taking the length to be the distance from the surface boundary[1] to the local point of interest.
H * H_x/ k
I'm not sure where your question comes from, but the Nu number is used for flat surfaces being heated by fluids (gas and liquid) above or below AND for circular problems like pipes and tubes. The Nu focuses on the film between the surface and the rest of the fluid. That has to be a "thickness", doesn't it? The Reynolds Number focuses on the length a fluid travels past a surface - because that affects turbulence and the how the heat gets transferred.
RE: nusselt number
RE: nusselt number
I'm guessing you didn't bother looking it up in Wikipedia, so here: http://en.wikipedia.org/wiki/Nusselt_number#Introd...
TTFN
