Fuel line materiales
Hi All,
I am working on a project to filter and conditioning fuel (propane), according to CSA B149.1-10, clause 6.2.8, I can choose CSST, seamless copper or seamless steel as the material of the tubing I will use in it. My question is can I use seamless stainless steel tubing instead? Because in Clause 6.2.12, it says "materials not specified in Clause 6.2 may be used if they conform to a nationally recognized standard or to a test report of a nationally recognized certification organization"
Thank you.
Sean
Thank you.
Sean
RE: Fuel line materiales
MJCronin
Sr. Process Engineer
