Creating non-mittered flanges
Hello! I´m having a doubt when creating flanges along multiple edges. If i select two edges as in the pictured the get automaticaly mittered. Is there a way to make them as drawn in red in the picture, without having to edit each flange profile?
I remember that when i was using autodesk inventor you get a button to configure each meeting flange, and change if is mittered or one over another.
RE: Creating non-mittered flanges
If there is, I haven't found it. One would think, though, that there should be that ability. I'd suggest sending in an enhancement request.
Jeff Mirisola, CSWE
My Blog
I've used joints like that before, and I couldn't find any 'automatic' tool to create them. I ended up manually cutting and adjusting.
I agree with the above - it would be a cool enhancement.
