End Radius!
End Radius!
End Radius!
Hi All,
First and foremost, I am trying to make a dimple on a brass sheet that is 0.8mm thick. The standard to which I am making these dimples say "Deep Dimple made with a 4.8mm rod with a 5mm end radius". Can anyone explain what your understanding of this is? Maybe my understanding of End radius is wrong. Thanks for your help.
RE: End Radius!
Is there any depth requirement in your "standard"?
RE: End Radius!
As noted, "DEEP" is relative and the required depth needs to be specified.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
RE: End Radius!
"4.8mm rod with a 5mm end radius"
Is the 4.8 the length or diameter? If the dia, would there be a point using a 5mm radius?
If the length, why call it out?
Chris, CSWA
SolidWorks 14
SolidWorks Legion
RE: End Radius!
@ Checker Hater - Yes thats it! thats the document. And yes I forgot to mention the depth. Its 1.5mm.
